Discuss What wet vac to buy? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Piperdave22
I’m looking to get a decent wet vac . I have been using a Charles but it’s started spitting out when full and not shutting off
Had a titan and it corroded through the bottom .
Want it for sucking up brick dust when chasing pipes but also for final clean Etc so don’t want it blowing dust everywhere .
Aswell as general plumbing uses obviously .
Only have a small van so one that does all would be ideal but I’m thinking it may be best to just buy two , one for wet and one for dry .
What are you all using / recommend. Don’t mind paying good money for it . If it’s a decent bit of kit.
Reply to What wet vac to buy? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi I need some advice as this has been ongoing since august and nobody can find a problem but meantime water is damaging my walls. The lady...
I live in a converted Victorian pub, and our kitchen and downstairs bathroom are at basement level. Behind the downstairs toilet there’s a...
2K
im of understanding that lots of you use wet vacs to remove the last bits of water from pipe work after draining a system, in order to carry out...
8K
Not sure if this is a success or a fail or just a rant but We do have heat and hot water now So all started the evening of Friday the 12th (Nov)...
2K
  • Locked
My 8 month old karcher wd3 decided to spit black radiator sludge over customers carpet the other day :mad:. So I'm on the market for a new vac...
4K
