Paul Vaz
hi everyone as a plumber what would carry as spare emergency plumbing fittings and what tools
Discuss what do i need in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I wondered where that string went ...
Items in pink are dependent on personal taste
Pump pliers
adjustable wrenches of various sizes
screwdrivers
drill
saw
hacksaw
sandwich box
stanley knife
benders
push fit stop ends
end feed elbows
couplers
street elbows
tees
coffee flask
pencil
spirit level
pipe cutters
pliers
tape measure
compression couplers
blow torch
solder
wire brushes
heat mat
napkin
chisels
torch
bicycle pump or similar
tile cutter
solvent weld
spare traps
sponge
hand cleaner
face flannel
brush
comb
hair gel
bucket
mop
spade
broom
flue gas analyser
smoke pump
oil pressure gauge
hammer
flow gauge
water pressure gauge
drill bits
set square
invoice book
business cards
newspaper
sweets
empty wallet
loose change
rope
organiser boxes
screws
immersion spanner
coat
change of clothes
nozzles
stanley knife blades
hose pipe
silicone (white and transparent) - possibly sensible cone as well
adhesive
40mm fittings
32mm fittings
wall plugs
22mm fittings
note book
Abba CD
ELO CD
Beethoven's 5th Symphony
Verdi's Requiem
bigger spirit level
smaller spirit level
pipe clips 10mm
15mm
22mm
tile cutter
32mm
40mm
10mm end feed elbows
couplers and tees (and more coffee)
40mm tees and bags
ladder?
stairway to Heaven?
another torch
job to go to
pencil in case you lost the first one mentioned
crisps
flux
chocolate
another heat mat
more chocolate
windscreen cleaner
spare tape measure
bottom feed inlet valves
spare pen
side inlet valves
phone
long nosed pliers
fire extinguisher
spare gas
funnel
rag
towels
vacuum
wet vacuum
dust pan and brush
small bucket
jaw droppers
screwdriver set
spare battery for drill
electric saw
mirror
kitchen roll
and a mobile office into which to keep all this clobber.
I bet I've missed something
Just out of curiosity what would keep in your other toolboxregards turnpin
spinach so i can carry the first oh and a small clay pipeJust out of curiosity what would keep in your other toolboxregards turnpin
Pump pliers
screwdrivers
drill
saw
hacksaw
sandwich box
stanley knife
benders
push fit stop ends
end feed elbows
couplers
street elbows
tees
coffee flask
pencil
spirit level
pipe cutters
pliers
tape measure
blow torch
solder
wire brushes
heat mat
napkin
chisels
torch
tile cutter
solvent weld
spare traps
sponge
hand cleaner
face flannel
brush
comb
hair gel
bucket
mop
spade
broom
flue gas analyser
smoke pump
oil pressure gauge
hammer
flow gauge
drill bits
set square
invoice book
business cards
newspaper
sweets
empty wallet
loose change
rope
organiser boxes
screws
immersion spanner
coat
change of clothes
nozzles
hose pipe
adhesive
40mm fittings
32mm fittings
wall plugs
22mm fittings
note book
Abba CD
ELO CD
Verdi's Requiem
bigger spirit level
pipe clips 10mm
15mm
22mm
tile cutter
32mm
40mm
40mm tees and bags
ladder?
stairway to Heaven?
another torch
job to go to
crisps
flux
chocolate
another heat mat
more chocolate
windscreen cleaner
spare tape measure
spare pen
side inlet valves
phone
long nosed pliers
fire extinguisher
spare gas
funnel
rag
towels
vacuum
wet vacuum
dust pan and brush
small bucket
jaw droppers
screwdriver set
electric saw
mirror
kitchen roll
Pump pliers
screwdrivers
drill
saw
hacksaw
sandwich box
stanley knife
benders
push fit stop ends
end feed elbows
couplers
street elbows
tees
coffee flask
pencil
spirit level
pipe cutters
pliers
tape measure
blow torch
solder
wire brushes
heat mat
napkin
chisels
torch
tile cutter
solvent weld
spare traps
sponge
hand cleaner
face flannel
brush
comb
hair gel
bucket
mop
spade
broom
flue gas analyser
smoke pump
oil pressure gauge
hammer
flow gauge
drill bits
set square
invoice book
business cards
newspaper
sweets
empty wallet
loose change
rope
organiser boxes
screws
immersion spanner
coat
change of clothes
nozzles
hose pipe
adhesive
40mm fittings
32mm fittings
wall plugs
22mm fittings
note book
Abba CD
ELO CD
Verdi's Requiem
bigger spirit level
pipe clips 10mm
15mm
22mm
tile cutter
32mm
40mm
40mm tees and bags
ladder?
stairway to Heaven?
another torch
job to go to
crisps
flux
chocolate
another heat mat
more chocolate
windscreen cleaner
spare tape measure
spare pen
side inlet valves
phone
long nosed pliers
fire extinguisher
spare gas
funnel
rag
towels
vacuum
wet vacuum
dust pan and brush
small bucket
jaw droppers
screwdriver set
electric saw
mirror
kitchen roll
Reply to what do i need in the Plumbing Jobs | The Job-board area at PlumbersForums.net
