Discuss what do i need in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Paul Vaz
hi everyone as a plumber what would carry as spare emergency plumbing fittings and what tools
i have a piece of string in my pocket, does anyone know what size it should be
I wondered where that string went ...
Items in pink are dependent on personal taste
Pump pliers
adjustable wrenches of various sizes
screwdrivers
drill
saw
hacksaw
sandwich box
stanley knife
benders
push fit stop ends
end feed elbows
couplers
street elbows
tees
coffee flask
pencil
spirit level
pipe cutters
pliers
tape measure
compression couplers
blow torch
solder
wire brushes
heat mat
napkin
chisels
torch
bicycle pump or similar
tile cutter
solvent weld
spare traps
sponge
hand cleaner
face flannel
brush
comb
hair gel
bucket
mop
spade
broom
flue gas analyser
smoke pump
oil pressure gauge
hammer
flow gauge
water pressure gauge
drill bits
set square
invoice book
business cards
newspaper
sweets
empty wallet
loose change
rope
organiser boxes
screws
immersion spanner
coat
change of clothes
nozzles
stanley knife blades
hose pipe
silicone (white and transparent) - possibly sensible cone as well
adhesive
40mm fittings
32mm fittings
wall plugs
22mm fittings
note book
Abba CD
ELO CD
Beethoven's 5th Symphony
Verdi's Requiem
bigger spirit level
smaller spirit level
pipe clips 10mm
15mm
22mm
tile cutter
32mm
40mm
10mm end feed elbows
couplers and tees (and more coffee)
40mm tees and bags
ladder?
stairway to Heaven?
another torch
job to go to
pencil in case you lost the first one mentioned
crisps
flux
chocolate
another heat mat
more chocolate
windscreen cleaner
spare tape measure
bottom feed inlet valves
spare pen
side inlet valves
phone
long nosed pliers
fire extinguisher
spare gas
funnel
rag
towels
vacuum
wet vacuum
dust pan and brush
small bucket
jaw droppers
screwdriver set
spare battery for drill
electric saw
mirror
kitchen roll
and a mobile office into which to keep all this clobber.
I bet I've missed something
Pump pliers
screwdrivers
drill
saw
hacksaw
sandwich box
stanley knife
benders
push fit stop ends
end feed elbows
couplers
street elbows
tees
coffee flask
pencil
spirit level
pipe cutters
pliers
tape measure
blow torch
solder
wire brushes
heat mat
napkin
chisels
torch
tile cutter
solvent weld
spare traps
sponge
hand cleaner
face flannel
brush
comb
hair gel
bucket
mop
spade
broom
flue gas analyser
smoke pump
oil pressure gauge
hammer
flow gauge
drill bits
set square
invoice book
business cards
newspaper
sweets
empty wallet
loose change
rope
organiser boxes
screws
immersion spanner
coat
change of clothes
nozzles
hose pipe
adhesive
40mm fittings
32mm fittings
wall plugs
22mm fittings
note book
Abba CD
ELO CD
Verdi's Requiem
bigger spirit level
pipe clips 10mm
15mm
22mm
tile cutter
32mm
40mm
40mm tees and bags
ladder?
stairway to Heaven?
another torch
job to go to
crisps
flux
chocolate
another heat mat
more chocolate
windscreen cleaner
spare tape measure
spare pen
side inlet valves
phone
long nosed pliers
fire extinguisher
spare gas
funnel
rag
towels
vacuum
wet vacuum
dust pan and brush
small bucket
jaw droppers
screwdriver set
electric saw
mirror
kitchen roll
Just out of curiosity what would keep in your other toolbox:):)regards turnpin
i keep thinking of things then scroll up and down and he has them on the list, i'm giving up looking, watching sky sports, Man U lost 4-0 in the cup, and Frankie Boyle prog is on at 10pm, ( young plumber of the year is on at 10.30pm on BBC 3 if anyone cares) it will actually still be on if you dont care!!!!
I did miss something - spare 10mm, 15mm, 22mm and 28mm pipe, and an old circulating pump, and plastic plumbing fittings, washers, syphons ... there's so much flamin' stuff you need
And new van brochures
Pump pliers
screwdrivers
drill
saw
hacksaw
sandwich box
stanley knife
benders
push fit stop ends
end feed elbows
couplers
street elbows
tees
coffee flask
pencil
spirit level
pipe cutters
pliers
tape measure
blow torch
solder
wire brushes
heat mat
napkin
chisels
torch
tile cutter
solvent weld
spare traps
sponge
hand cleaner
face flannel
brush
comb
hair gel
bucket
mop
spade
broom
flue gas analyser
smoke pump
oil pressure gauge
hammer
flow gauge
drill bits
set square
invoice book
business cards
newspaper
sweets
empty wallet
loose change
rope
organiser boxes
screws
immersion spanner
coat
change of clothes
nozzles
hose pipe
adhesive
40mm fittings
32mm fittings
wall plugs
22mm fittings
note book
Abba CD
ELO CD
Verdi's Requiem
bigger spirit level
pipe clips 10mm
15mm
22mm
tile cutter
32mm
40mm
40mm tees and bags
ladder?
stairway to Heaven?
another torch
job to go to
crisps
flux
chocolate
another heat mat
more chocolate
windscreen cleaner
spare tape measure
spare pen
side inlet valves
phone
long nosed pliers
fire extinguisher
spare gas
funnel
rag
towels
vacuum
wet vacuum
dust pan and brush
small bucket
jaw droppers
screwdriver set
electric saw
mirror
kitchen roll
hairdryer good for wet pcbs and conden pipes
You have missed off ptfe tape - how dare you!
Any self respecting 'pseudo-plumber' can fix anything with a few rolls of this!
When I am called out to a leak I just smother everything in boss-white, and mummify the pipework with ptfe tape. Job done - £100 please!!!
Pump pliers
screwdrivers
drill
saw
hacksaw
sandwich box
stanley knife
benders
push fit stop ends
end feed elbows
couplers
street elbows
tees
coffee flask
pencil
spirit level
pipe cutters
pliers
tape measure
blow torch
solder
wire brushes
heat mat
napkin
chisels
torch
tile cutter
solvent weld
spare traps
sponge
hand cleaner
face flannel
brush
comb
hair gel
bucket
mop
spade
broom
flue gas analyser
smoke pump
oil pressure gauge
hammer
flow gauge
drill bits
set square
invoice book
business cards
newspaper
sweets
empty wallet
loose change
rope
organiser boxes
screws
immersion spanner
coat
change of clothes
nozzles
hose pipe
adhesive
40mm fittings
32mm fittings
wall plugs
22mm fittings
note book
Abba CD
ELO CD
Verdi's Requiem
bigger spirit level
pipe clips 10mm
15mm
22mm
tile cutter
32mm
40mm
40mm tees and bags
ladder?
stairway to Heaven?
another torch
job to go to
crisps
flux
chocolate
another heat mat
more chocolate
windscreen cleaner
spare tape measure
spare pen
side inlet valves
phone
long nosed pliers
fire extinguisher
spare gas
funnel
rag
towels
vacuum
wet vacuum
dust pan and brush
small bucket
jaw droppers
screwdriver set
electric saw
mirror
kitchen roll
did you copy and paste this from some where ? or actually sit and write all this out lol
Knowing DK he sat and wrote it out. Handy though, I just copied it to answer my bosses question about essential van stock.
No doubt I'll be ignored again!
I typed it - in an earlier job I turned into a secretary (don't ask how!) I ended up typing at 90wpm which was faster than most women and I still couldn't get a secretarial temping job with that speed.
I'm not such an anorak that I took my laptop out to the van though, in case you were all wondering.
:cool:
And where's me bloomin' Thank You from the OP for all the time and trouble?:mad:
:p:p
Oh, most of the posters on here are like that - they are all 'can you help me pretty please?'
When you do they are off like a rat out of an aquaduct - poof!!
Not a hint of a thanks . . .
I am copying those lists and then make them standard for our van stock
+ diesel card
centralheatking
Reply to what do i need in the Plumbing Jobs | The Job-board area at PlumbersForums.net
