Currently reading:
Wet and Dry Vac
Discuss Wet and Dry Vac in the Plumbing Jobs | The Job-board area at PlumbersForums.net
tolly
Hi I've seen screw fix are doing karcha ones for under 50quid would have thought it will be quite good
I got the £35 from b and q and it hasn't let me down yet
Just have to empty it more often
I've got a Titan one from Screwfix, paid around £40 for it, no complaints.
I bought a Karcher from Plumbfix. Problem is the seal is poor and it has the habit of spraying water all over customers lovely new carpets. It now lives in the garage with all the other useless tools I have bought over the years.
Its funny how forums vary in opinion. I asked this on another forum a few times and general opinion was anything under £100 was rubbish !
Karcher ones are utter tosh, bad filter design and they leak. don't bother. Just bought myself a nilfisk multi on Wednesday and its immeasurably better.
Wickes one's are great IMO I used them for allsorts in the past but they seem to change every 3 years now getting a new filter is immposible so need a new one myself
Best wet vac by far is to get your mouth over a bit of inch and a half pipe and sook for Britain.
No leccy costs or leaky filters to worry about either.
I use the Earlex mainly for servicing. great little hoover!
[DLMURL="http://www.earlex.co.uk/wd1000.html"]Earlex | HVLP SprayStations, wallpaper strippers, heat guns, wet 'n' dry vacs, steam cleaners[/DLMURL]
I've got the Wickes one as well. Great little machine, does the job but cheap enough that I'm not too precious about it. I didn't fit the castors and chucked all the tools out as all I want is the hose. Don't need any fancy filters as it's just used for wet pick up, the Henry is used for dry work. Gets me out of trouble at least once a week. This weeks one was catching the water as I cut out a blocked cold feed, ten feet of pipe above the blockage which was directly above the boiler.
has anyone used the Metabo as1200 wet/dry vacuum? can be had for less than a Henry or George and seems to have almost identical spec apart from capacity is much larger on the Metabo model.
he wasnt cheap but I luv my george does wet and dry and wet cleans the carpet when you really cock up a rad removal.
bought my wickes vac as my vax one kept leaking black stuff on carpets.
I took it in the attic today and it fitted through a small gap, meaning that i dint have to bring the F&E down to clean it out.
mine is light, doesnt leak, very powerful (used it for cleaning F&E tank then emptied it and used it 10 minutes later to hoover carpet of dust from attic.
I am so impressed.
Only issue is that the filter ends up getting wet when it is full so be careful when opening.
And also the wickes one has a blow side aswell, meaning that if you have a blockage in pipe you could try pushing it out aswell as sucking it out and also clean filters/ boilers out with it for that hard to reach dust/ dirt
Would fancy doing that on a saniflow!!
Reply to Wet and Dry Vac in the Plumbing Jobs | The Job-board area at PlumbersForums.net
