Discuss Water meter readings 22mm vs 15mm? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Pieter
Good day
My question is concenrning a system where the main water meter is on a 22mm water line, this line is then split to 15mm lines.
Will the 22mm line water meter have a larger reading over the 15mm line water meter?
All water meters are calibrated to read the volume of water that flow through them, it doesn't make any difference what the pipe / meter size is.
A larger / smaller meter or a larger / smaller pipe connected to the meter won't affect the reading.
Reply to Water meter readings 22mm vs 15mm? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hello, I have quite low flow rate for my electric shower (a piddling 5L/min), and would like some tips or advice about how to solve or find the...
Essaboy
E
I live in Azerbaijan and am looking to revamp the water system in my house. The first thing is that I don't have a water meter - probably a good...
Hi all, I currently have an external water meter (which is a sub-meter) of my neighbours meter. The mains supply runs into their garden and then...
Hello everyone, I'm facing a rather complex situation and I need your expert advice. My neighbor and I share a boiler for hot water, and we have...
