Discuss Warning- gas leak developed on new B&Q hob 1 hour after fitting in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
Mike Jackson
Just got back from a call out to a leaking hob that I finished fitting at 4 this afternoon. Fitted using the supplied fitting tested it up and all was fine. Had a call back to it at 5. Owner had lit the hob and it had gone with a bang. Told him to turn off the gas and went back round to it. Put a tightness test on and there was now a big drop. Checked under the hob and the connecting nut was only finger tight. Took it apart and the rubber washer, which was supplied, had deformed and gone up inside the pipe. I remade the connection using a fibre gas washer and it's all fine again. it wouldn't have been so bad if it had happened straight away but to do it after I had left is very dodgy.
I shall be complaining to B&Q and reporting it to gas safe on Monday.
the hob is a Cata GH60SS gas hob.
thanks for posting that up mike,sounds like a very poor design
No not the sort to mess and the connection was behind the built in oven.
I would think a RIDDOR report rather than Gassafe, cant see them being interested.
I will from now on. I'll have to get some more fibre gas washers in.
It is the flat face to face thing that makes it worse. There is no rim to hold the rubber washer from binding and twisting inside the fitting/pipe and we are supposed to believe the manu's test and certify this stuff. I just would never trust them for gas as i've seen (as you now have too) what can happen with them.
A year or 2 ago the gas networks had to have a recall of their meter washers after they swapped their supplier to a different manu who produced a harder more plasticy washer (for much cheapness no doubt). It was found that these washers relaxed after tightening and they were being called out to leaks within days of their meters being fitted.
This trade is no different to anything else. Everything is about the money.
A riddor won't do nothing but i suppose if enough people did they might follow it up.
Reply to Warning- gas leak developed on new B&Q hob 1 hour after fitting in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi there, I am hoping someone can give me some advice. We have had two leaks at home in the last 2 weeks; luckily we were in for both events and...
Hi all, We recently purchased a house and nothing seems to work correctly here, I've spent weeks rectifying issues. Plumbing, electrical...
5K
We have a Glowworm BBU56F (back boiler). Its well-maintained/serviced and since we’ve been in the property (15 years) only the Thermocouple was...
6K
Hello hope someone can help. So this morning woke up to a f28 on my Vaillant eco tec pro 28.so did the usual things checked standing pressure and...
1K
Ah, the joys of older home ownership (1974). We thought our major plumbing issues were dealt with when we got rid of our orangeburg sewer line and...
2K
