Currently reading:
Vulane Express Gas Torch
Discuss Vulane Express Gas Torch in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Supplied complete with soldering tongs (4 metre cable)... Wicked! :goofy:
Very slow though. I've got a monument electrical inductance soldering machine and it takes around 4 times as long as with a blow torch. Very handy if you're working very close to highly flammable materials. I was doing a boiler and cylinder swap a few years ago and the cylinder cupboard was lined with polystyrene tiles. Even with a heat mat the tiles would have melted using a blow torch. The customer queried why I was using it and I explained about the fire risk and he seemed quite impressed. He was even more impressed next day when I went back and the front page of his paper had a picture of a listed building burnt to the ground by a plumbing apprentice.
I always remove the gas bottle. I heard that you can be fined up to £1000 if the police stop you and see it. Anyone know if that's actually true?
I've heard of them leaking and blowing up too along the way
Those leaking one were earlier this year and called back to the suppliers
Propane gas bottles ALWAYS leak when u disconnect them. I turn flame off and turn it down and leave it connected
Very slow though. I've got a monument electrical inductance soldering machine .
I do some work in places where the fire alarms & smoke detectors can't be turned off so can't use a blow torch.
Does your machine set off any alarms ?
It can cause smoke if you use too much flux. A lot less than a torch though.
your problem , I speak 3 languages !
I never look for problems , I am hear to chill and have a good time !
I dont use any , if it goes of the alarm I let it run ......
,but if its one of them places where the fire alarm is linked worth the local fire station then is a big risk as the could be charged for a them coming over and not been a real fire (bit disappointing really ) pmsl
Reply to Vulane Express Gas Torch in the Plumbing Jobs | The Job-board area at PlumbersForums.net
