Discuss Viessmann Vitodens. Hot weather, no hot water in the Plumbing Jobs | The Job-board area at PlumbersForums.net
We had this problem for a few days last year, but has appeared again. During these warmer temperatures that we are currently experiencing our boiler stops heating the hot water. Upto a couple of days ago when it was cooler it was working fine, and if as last year as soon as it cools off again it will be back to normal working.
Conventional condensing boiler (not combi), it does have the outside weather compensating sensor.
Anyone any ideas - I'll look into getting an engineer in over the next week, but suggestions might help point him in the right direction if these problems have been experienced previously.
JP
sounds like weather comp is holding the boiler off
@townfanjon
Vitodens 100-w 35kw. 2x 22mm pipes to boiler; flow to pump to valve, plus a return.
Yes, heating working, just checked.
Might add that the hot water heats OK when set to come on in the early hours when it's much cooler outside.
Thanks for your patience ;)
100w open vent
Reply to Viessmann Vitodens. Hot weather, no hot water in the Plumbing Jobs | The Job-board area at PlumbersForums.net
