- Messages
- 97
Sorry Kop. Youve lost me on this one....Never had a problem with Monarch water softeners and reasonably priced , I'd maybe think hard and get both boiler and cylinder done fit weather compensation is a must now to save energy. Kop
Discuss Unvented cylinder size in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
CAnt fit this as i havnt quite got the head height in the loft...I often spec for 'Gledhill platinum stainless indirect' cylinders. I rate them and they have the floating baffle that eliminates need for expansion vessel and adds a decent amount of accumulation that may help with your 'pressure' issues
Here's one I recommend around £500 . KopYeah, thats the one, it still works and gives us heat! Its bastard expensive to run mind...
Im not against upgrading it, but i need to justify the cost against the working unit tbh...
Water softners a thing to look at....? Whats the best thing without spending a million bucks....
Lost how mate? A new boiler and unvented cylinder with the boiler wired to a external weather sensor , I've recommended a water softener above . KopSorry Kop. Youve lost me on this one....
Many thanks Kop. External weather sensor....Lost how mate? A new boiler and unvented cylinder with the boiler wired to a external weather sensor , I've recommended a water softener above . Kop
SO, at present im on a y plan, am i right in thinking, with an unvented a cylinder, it would be best to change over to an s plan, with the two valves close to the boiler? And if so, do i require an extra 5 or 6 core wire to link up new valves,??Lost how mate? A new boiler and unvented cylinder with the boiler wired to a external weather sensor , I've recommended a water softener above . Kop
Weather compensation, if that's what you are still considering (I've lost track), is incompatible with standard S-plan with a cylinder as one zone because most of the time the CH water is below the 65°C minimum needed to heat the cylinder.SO, at present im on a y plan, am i right in thinking, with an unvented a cylinder, it would be best to change over to an s plan, with the two valves close to the boiler?
Me 2!Weather compensation, if that's what you are still considering (I've lost track), is incompatible with standard S-plan with a cylinder as one zone because most of the time the CH water is below the 65°C minimum needed to heat the cylinder.
5 core and basically yes I'd change the 3 port to two or even 3 - 2 ports zone valves does your property need to be as warm upstairs as it does downstairs?SO, at present im on a y plan, am i right in thinking, with an unvented a cylinder, it would be best to change over to an s plan, with the two valves close to the boiler? And if so, do i require an extra 5 or 6 core wire to link up new valves,??
If the y plan stays, i assume the new valve just goes near the cylinder somewhere and gets wired to the control centre....
Just want to try and do half a job! But do it right once!
New boiler is a bit costly at present...
Reply to Unvented cylinder size in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
