Discuss Unusual mains stop tap key in the Plumbing Jobs | The Job-board area at PlumbersForums.net
O
oldmanriver
I have been trying to lay my hands on a street mains stop tap key for my house. Its an unusual variety being a spindle type with a "D" shaped fitting. The flat face of the D is about half an inch across. All my local plumbers and merchants say they have heard of the key but never been able to get one despite thousands of houses hereabouts having that type of tap. The word seems to be that United Utilities are deliberately making it impossible to get hold of them and none have been available to wholesalers for several years.
I have trawled the internet and it does seem to be a fact that they are impossible to find, although I did find a universal friction type that might have worked but the supplier ignored my calls and emails.
I attach a photo of the mains tap in question. If anyone recognises the type and can tell me where I can get hold of one I 'd be really grateful.
Cheers
i reacon an adjustable tap spanner would work on that. If not id make a tool out of 3/4 mild steel tube and bend or weld a flat side in it... other than that, i havent seen a proper tool
To me that looks like a frost cover to protect the stop valve and/or meter with a metal rod to help keep it in place.
Is that "circle" around 4" across with the metal bit near the middle? Because if it is, you'll have to remove it to access the stop tap further down. The stop valve is generally around half an arm to an arm's length below the ground surface.
Of course I could be talking through my hat!
How about using a univeral socket on a long bar.
[DLMURL="http://www.axminster.co.uk/product-Wiha-Gripper-Socket-23229.htm"]Gripper Socket : Buy Gripper Socket at Axminster Power Tool Centre[/DLMURL]
Mike
how about try cheating,
ring the waterboard at about 2pm, "i have a leak on my internal stop tap, and their stop tap in the street wont shut off"
the engineers that attend will enjoy an early finish that day, and if you give them a couple of brews and a bacon butty, may accidentally leave their spanner behind.
ive never seen this fitting before, but that dosnt mean a thing, on the replies above id go for dontknowitall knowing it best...
shaun
Thanks for all the really helpful input guys. I am going to try adjustable tap spanner or some other universal grip, but its nearly 3feet below pavement level so a bit of a stretch. Or I may fabricate something. Water coy have been rubbish dont want to know and really unhelpful so if all else fails I am minded to take migoplumbers advice and cry help help and see what I can sort out with the guys who turn up!:)
The "D" type keys are a pain to find, they are only used by the water board.
If you still need a key pls contact me and i may be able to help you out with one.
Use my link below to contact me as I dont always check my msg`s on here.
Reply to Unusual mains stop tap key in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Forgive my ignorance, with this basic question, but I seem to be struggling to both understand, search for, and source, the appropriate washer...
We have just moved in to a 1934 Semi- and I am getting round a few simple DIY tasks, including a couple of plumbing-part renewals such as modern...
Hi All After having pooling water on my drive, I dug down around to find: Black pipe poly/plastic dug 450mm deep spraying water at mains...
I have read a few threads including one by Debbie Stano that were similar to my issue but that thread stopped a while back without any resolution...
I have a seemingly impossible problem. I am not a plumber but I can at least understand some of it. We have just had the Water Board inspector...
