Discuss Two rads + room thermostat - omit TRVs on one, or both? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
S80
Hi Guys - just a quickie!
I'm aware that a TRV shouldn't be fitted to a rad in a thermostat-controlled room, but does that apply to all rads, when more than one is fitted in the room - regardless of how they may be proportioned?
Cheers
I'm aware that a TRV shouldn't be fitted to a rad in a thermostat-controlled room?
Cheers
you answered your own question there very quickly :)
Thanks for that. The living room in our house must have been 'knocked through' at some point, so one rad has a TRV and one doesn't!
Reply to Two rads + room thermostat - omit TRVs on one, or both? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Would like some help please as my Drayton Wiser system is a mess. I had 2 TRVs in the lounge, one in the main bedroom, the rest of the house - 6...
Jaga radiators (with heat-exchangers) have their own small fans, that "will modulate down when the room temperature is met – the room temperature...
Hi - I'm a reasonably experienced DIY plumber but just can't work out why the last new rad I've installed is cold - would really appreciate your...
Hi, I just moved into a new house and it has a Glow Worm Compact 24c combi boiler and a ESI ESRTP4RF+ programmable room thermostat and I am...
Hi All I'm planning on replacing a couple of rads soon as they are far too small for the size of the room causing the room to take an age to heat...
