Discuss To you builders in the Plumbing Jobs | The Job-board area at PlumbersForums.net
hammers4spanner
Subscribed
I know some of you do builds and extensions along with your plumbing so some advice please.
On a permissible build can you literally do what you want as in block some of your neighbours light out?
yes all you can do is bring it up when the application goes through/is sent in
No right to light.
I take it when you say permissable you mean something that doesnt need planning permission?
Yes a build that requires no planning , however in this case the build will come right across front room window about 10 foot off it.
Previous no wall there so how does that equate?
Reply to To you builders in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi everyone I hope you can help. We were getting some work done and our builder attached the boiler condensate pipe to the sink waste pipe. This was all then covered with dot and dab. Shown in the picture, red arrow. So the only thing visible now is a round pipe from the wall. We are yet to fit...
Hello Everyone ;0 Iv just discovered this forum, looking through internet to find a solution to my small problem. So I just reopened, builders opening in my 1930 ex-council house. And surprisingly, did find some pipes inside. Two look like water - those have been cut, and those are like side...
Hello, We had an extension built seven years ago. Initially the builders' plumber connected the heating to the house system but this didn't work. The builder got him out again and he created a separate heating circuit from the boiler (ie one circuit for the house, the other for the extension)...
Hello all I have had an extension built which will have 3 radiators to the big main room, a utility sink and a shower room (ground works, waste, and pipes etc are in) The builder is not installing the sanitary ware as I will have to save up in order to fit the shower room in a few years time...
Hi, I'm looking for a gas engineer who I can work with so I can complete my portfolio. I have done level 2 and 3 tech cert along with bpec gas foundation and in order to progress to ACS, I have to finish my portfolio. I also want to learn plumbing along with gas so I can learn more things. I...
