Discuss Thermostatic mixer bath taps in the DIY Plumbing Forum area at PlumbersForums.net
Just replaced taps on bath so kids can get a shower in bath as well ,worked fine to started with then water wasn't hot so took them back and exchanged them ,now these are doing same any ideas anybody ?
What type of system do you have ? Eg combi cylinder etc
Is cold from a tank or mains
Do you have tanks in the loft ?
was your exsisting bath taps 2 seporate taps (a hot tap and cold tap out of 2 spouts?)
Is your new tap a bridge tap ie a single spout out the middle?
if you turn the hot tap on only are you not getting any water all all or just cold water?
Reply to Thermostatic mixer bath taps in the DIY Plumbing Forum area at PlumbersForums.net
Hi bit of a weird issue, I installed a grohe bathroom tap successfully 2 months ago bought from screwfix. Last week the right hand hot tap makes...
Our kitchen mixer tap has started dripping. Like so much of the plumbing in our almost new build bungalow, it is lacking! The plumber didn't...
Just started gound work on self build bungalow and wondering best way to do below ground soil pipes. For toilet I was going to go straight down...
Can anyone remember the Mira mixer shower that would work down to a really low pressure on a vented hot water system without a shower pump?
