Discuss Thermostatic mixer bath taps in the DIY Plumbing Forum area at PlumbersForums.net
Just replaced taps on bath so kids can get a shower in bath as well ,worked fine to started with then water wasn't hot so took them back and exchanged them ,now these are doing same any ideas anybody ?
What type of system do you have ? Eg combi cylinder etc
Is cold from a tank or mains
Do you have tanks in the loft ?
was your exsisting bath taps 2 seporate taps (a hot tap and cold tap out of 2 spouts?)
Is your new tap a bridge tap ie a single spout out the middle?
if you turn the hot tap on only are you not getting any water all all or just cold water?
Reply to Thermostatic mixer bath taps in the DIY Plumbing Forum area at PlumbersForums.net
