Discuss Thermostat and Valve Actuator reverse problem in the Central Heating Forum area at PlumbersForums.net
I have just installed a new Drayton zone replacement valve , model ZA5.
The good news is that the value is working; however, the issue I'm experiencing is that when my thermostat turns the central heating on, the valve moves to the off position and the valve closes and when I turn off the central heating from the thermostat the valve moves to the on position and the valve opens.
I have a hive thermostat already installed.
Any idea what's happened and how I can fix this?
I've tried my best to place the wires in the exact same place where I removed the old value wires but as you will see the wiring/control centre is a shambles.
Please let me know if you require more pictures or information.
Thank you
Meethi
Reply to Thermostat and Valve Actuator reverse problem in the Central Heating Forum area at PlumbersForums.net
I have a heating system comprised of skirting radiators that form part of a loop from the boiler, round the house and back. Some rooms get...
Hi I have a fully pumped heating system fitted with a Drayton MA1 diverter, after the summer run the heating stopped coming on, so I replaced the...
Have a sytem boiler with unvented cylinder with 2 heating zones plus hot water in a house we moved into recently. To start with we were always...
Hi everyone, my first post here so go easy on me... 😄 I have Danfoss HPA2 motorised valves fitted to my heating system and one of them is giving...
