Discuss Thermostat and Valve Actuator reverse problem in the Central Heating Forum area at PlumbersForums.net
I have just installed a new Drayton zone replacement valve , model ZA5.
The good news is that the value is working; however, the issue I'm experiencing is that when my thermostat turns the central heating on, the valve moves to the off position and the valve closes and when I turn off the central heating from the thermostat the valve moves to the on position and the valve opens.
I have a hive thermostat already installed.
Any idea what's happened and how I can fix this?
I've tried my best to place the wires in the exact same place where I removed the old value wires but as you will see the wiring/control centre is a shambles.
Please let me know if you require more pictures or information.
Thank you
Meethi
Reply to Thermostat and Valve Actuator reverse problem in the Central Heating Forum area at PlumbersForums.net
