Discuss Tapping sound in pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
dtrom1984
Hi there hoping someone can help (I am not an expert at all!). We have a 2 year old house and in the airing cupboard I have noticed a taping sound (started about 2 days ago) - it is like water dripping within the pipe. The tapping is coming from either the black or white part of the pipe as per the photo above. This pipe feeds in to the cylinder as per below:
Any advice gratefully received!
Thanks.
Welcome to the forum, I`ll let the gsr guy`s advise you further.
the safety valve will be letting water down the black bit (tundish) into the white bit (dry trap). youll need to get a g3 plumber round to find out why...Welcome anyway..
Yep, the tapping is actually a dripping sound... Chinese water torture ;)
If you don't get the tapping noise when the heats off then it's likely to be a pipe expanding and rubbing against some wood,a temporary fix for a few months is lubricate the pipe as it enters the floorboard by squirting some washing up liquid down there
Thank you all for your help - this forum is brilliant!
Unfortunately the noise is constant - heating/water on or off. I am thinking of getting a plumber to have a look at it? Could it be anything major?
At 2 year old I would think it is nothing too major.
It has to be serviced once a year by a G3 qualified plumber for safety and for units warranty (normally 25year)
The unit has a pressure limiting device, pressure relief valves and an expansion facility of a certain type to prevent ordinary excess pressure. Something is wrong with one or more of these and the G3 person will need to test and make adjustments.
The black part is a tundish, can you see water dripping, if so one of the relief valves is passing either temp on top of the cylinder or relief linked to the inlet reducing valve
As said previously, please get in a pro to look at it. And make sure that he has a g3/unvented qualification.
Reply to Tapping sound in pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I am probably being unduly paranoid here but I noticed under our kitchen sink that there is some corrosion evident on a small section of copper pipe between compression fittings on the hot water feed. There are take offs for an outside hot and cold tap together with isolation valves and...
Hi everyone, I turned my cold water feed off in the airing cupboard which supplies only cold water to my bathroom but it also turned the water to my toilet off is that a correct set up? Because it didn't used to before the stop valve in airing cupboard only turned off the cold water supply to...
Prompted by a surveyors energy efficiency report (and getting grants as this job belongs to a small charity) I've been asked to lag the pipes in this boiler cupboard. So questions: 1.Anybody got a photo of a good professional job please. 2. Where to stop the insulation under the boiler...
Hello I am desperate for some help. Basically we are having our bathroom renovated. The plumber removed the units, including the sink a few days ago and this morning i noticed water dripping from the ceiling below. I went up to the bathroom and saw that one of the pipes (which originaly...
Deleted member 120897
We have just moved in to a 1934 Semi- and I am getting round a few simple DIY tasks, including a couple of plumbing-part renewals such as modern pipe/u-bend/fittings to kitchen sink, rinse sink etc as preventative maintenance! Nothing complex or specialist, that's for you expert guys! But in...
