Discuss Corrosion on Pipe / Fittings in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
I am probably being unduly paranoid here but I noticed under our kitchen sink that there is some corrosion evident on a small section of copper pipe between compression fittings on the hot water
feed. There are take offs for an outside hot and cold tap together with isolation valves and further up flexi hoses for the kitchen taps.
I have a suspicion about what might be the cause... Given the humidity in the kitchen especially when running condensing tumble dryers etc, condensation might be forming on the fittings and dripping down / collecting on the small section of (now green) copper pipe. Although the corrosion is on the hot feed, the water runs cold for quite some time before getting hot as the pipes are buried within the floor.
Of course, this may also be an old leak that has sealed itself. It's not causing an issue now but perhaps something I should get my plumber to inspect. My view in any event is that I'd prefer a soldered joint / take off for the hot (ignore the blue handle) as opposed to a compression fitting that somebody has fitted.
Currently trying to attach photos but keep getting server error.
Thanks...
Are you doing it via attach files eg opposite end to post ?
Attachments... Thanks for fixing it.
Micro leak thatā€™s sealed itā€™s self šŸ‘
Reply to Corrosion on Pipe / Fittings in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
