Discuss Suggestions for a toilet cistern - low level concealed. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Eyespy999
Afternoon,
I am looking at replacing the toilet cistern / flush on a concealed, low level toilet, it is concealed behind stud and tiles but has limited access from the top. The actual cistern is okay just looking at replacing the flush and probably top entry fill to a more environmental push button flush.
I have seen air operated flushes, but on a budget!
You can pick up fluidmaster flush & fill valves for a good price... Go too cheap & it will be more hassle than it's worth. Try screwfix
Sorry, I was after a modern flush which uses less water than a swimming pool I currently have and if anyone can suggest a make.
How are you going to change the flush valve if is concealed behind tiles?
It could be tricky. Is there a service hatch?
Modern toilers are designed to use less... Yours might not flush as well if you put less water down it.
Yes there more economical when you can use the small flush button, but not so much when the washer wears & lets water into the pan day & night ;)
Fluidmaster is the make to go for...
If the water usage is your concern then fill 2 small bottles with water and put them in the cistern however when using less water people can find that the waste matter doesn`t always flush away.
not just a pretty face are ya. Genius
Reply to Suggestions for a toilet cistern - low level concealed. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
Hello, we were misadvised on how much a Lusso Stone cistern could be cut down (by both the architects and Lusso). The bathroom has been plumbed /...
Hello, I'm seeking advice on resolving the persistent blockage issues with my downstairs toilet. A year ago, I replaced an 80s close-coupled...
Hi all Relatively inexperienced homeowner here. Apologies in advance if I get any terminology wrong. Today I noticed some limescale accumulation...
T
Hi all, seeking advice on my toilet. (Layman here, please be gentle with me.) When we flush the loo upstairs, it flushes fine (therefore assuming...
What's everyones top choice for a dual flush concealed cistern? It's going into a 600 by 400 unit with access through the dummy drawer front. The...
2K
