Discuss Best concealed cistern in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
What's everyones top choice for a dual flush concealed cistern? It's going into a 600 by 400 unit with access through the dummy drawer front. The toilet will be a wall hung on a low height frame.
The reason I don't want a combined frame and cistern is because the huge flush plates will not fit the unit.
Thanks, I was looking at the grohe, I've seen some reports of the flush pipe leaking, have you had any issues?
I see lots of recommendations for the fluidmaster, the thing that puts me off those is the flush plate is not as slick looking as the grohe.
Reply to Best concealed cistern in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
