Discuss Strap boss leak between strap and pipe in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hey all,
I’ve got a new section of stack fitted but when I fitted the strap boss I was too keen to test it and it now slightly leaks where it meets the stack.
I was wondering whether it’s worth trying to get it off and have another go or just replace the full piece (about 2 metres )
If I did replace would I just need to slide the top tee out, fit new piece from bottom up to the tee and then pivot the tee in and fit the top piece of piece going to the vent?
I thought about a slip coupling too.
Thankyou
Ps I used solvent weld
Buy a new strap boss just in case you break existing, but I reckon you’ll likely be able to stick a flat screwdriver up into the leak gap and pry of the existing boss.
Make sure you sand the shine off the pipe where the boss sits and ensure it’s in the correct orientation.
Reply to Strap boss leak between strap and pipe in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Trying to connect up new 40mm waste into the old soil stack (which would be an absolute pain to remove), it's all Osma pipe, from the 70s...
G
Morning everyone. Got an issue with an internal soil stack boss strap failure. The boss strap had been sealed originally with silicon which has...
Hi, I have an opening on the 'manifold' (I think that's what its called) on my soil pipe. It appears to be a non-standard size - about 51mm...
Hi! Totally inexperienced DIY newbie so bear with me for descriptions! Pictures hopefully help. I’m trying to remove an unused downstairs toilet...
Hi all, Have got an old 60/70s PVC soil stack, the Toilet is going into a Hunter branded socket which has an old O-ring design (quite flat with 3...
