Discuss Spirotech MB3 filter blocked ? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
L
Leshouches
I have a Spirotech MB3 fitted to the return on my boiler and it seems to be blocked as I cant flush it clean in the usual way. The Mb3 has been catching a fair bit of crud. Its not restricting flow.
Any ideas regarding the best method of clearing the filter blockage, hopefully without removing the Mb3 ?
Thanks.
It may be just a blockage in the outlet. You could try poking a screwdriver or something up to clear it but be prepared to get wet.
Thanks ... a prod with a screwdriver did it. It was full of magnite chunks. Fortunately it had an isolation valve on one side and the pump valve on the other.
Thanks for your reply.
Thanks for letting us know the outcome. Glad you've got it sorted.
Reply to Spirotech MB3 filter blocked ? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I have 3 port value for HW & CH. Loft extension added many years ago so they added a T to go upstairs, only 2 rads up but 11 downstairs...
Hi, Solar thermal not so big these days but a couple of Q for anyone who still works in it. Background. I'm an Electrician not a plumber.. I've...
I have a central heating system in a 7yr old ‘Persimmons’ new build, that has several problems related to reduced flow. A nice retired engineer...
1K
R
Hi all, I'm hoping someone on here will be able to help me with an issue I'm having at home. We've just returned from a week long holiday and have...
Laurie1987
L
Hello all. I've just joined, was going to post in the new members forum, but the first site generated email sent me here... I am here, as have a...
3K
