Discuss Size matters, even in radiators. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
Canada Bob
I hope someone can help me out on this one, I recently bought a house that's approx 30 years old and I'm working my way through it bringing stuff up to date.
The radiators {flat panel} are probably the original ones but I can't fathom if they are Imperial or Metric sizes, most of them are 75" / 1900mm long and that doesn't seem to have been a standard Imperial or Metric size.
If it helps they are single panel, finned, and 24" tall, I'd prefer not to have to rework the piping.
If I can't get rads this length would it be a bad idea to have them refurbished {blasted and painted}, or are they {as steel rads} likely to be rotten inside ? looked like Guinness when I flushed them out...
Thanks for your time and consideration.
Bob.
Bob , in the long term you would be best to change them for more modern efficient ones. You will win in the end
Welcome to the forum's Bob...have to agree with tfj...whilst your at this stage best to upgrade rads and alter pipe work to suit....regards Turnpin:welcome:
Yea but, No but, I agree with you {for the long run} but I need to do something now that doesn't demand reworking the pipes or making the job look like an engine room :-(
Any idea what those rad sizes were, probably Imperial ?
6ft 3in what's that, might have worked {years ago} for Policemen but 6ft 3in rads !!!
If short term solution why not take all rads off and flush individually outside with hose then refit with new valves and flush whole system with chemical and add magnetic filter. Hopefully nice clean system without changing rads and pipework for short term?
But would agree with others that best to just upgrade all now as will save money in the future.
Thanks for the suggestions, I'll probably go that route, but I'm still trying to figure out if 6ft 3in was a standard Imperial size ?
Reply to Size matters, even in radiators. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Having recently replaced my condensing gas boiler, i decided to upgrade two small double radiators which were located in a room which had been...
I've search on the internet for many hours but cannot find the solution I need. I have got a very old radiator in my house that fell off the...
5K
Deleted member 120897
Hi all, We recently purchased a house and nothing seems to work correctly here, I've spent weeks rectifying issues. Plumbing, electrical...
5K
Hi. I was hoping to change a radiator in my sitting room for a significantly larger one, but having read a few bits and pieces on the web, I'm...
14K
Good evening I'm hoping someone can provide a bit of guidance regarding radiators in our lounge please, I've read similar threads but not found...
1K
