Discuss Silicon remover in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Does this really work got a shower cubicle to refit
i usually pick off or cut off what i can then get meths on a rag and gently rub it off (doesnt mark either). with silicone remover be careful it doesn't damage the finish if its plastic.test it on a hidden bit first.
only put a bit on at a time though. also if ever you get scratches on anything acrylic like trays or baths, t cut gets mild ones out believe it or not. some bath manufacturers advise it for just that. have fun.
No it doesn't work as whyme says meths after you've took the heavy stuff off also kills any mould before you re silicone so win win really
Any big scratches then try a finger nail polishing file. Has 5 or 6 grades of sand paper down to the last one that polishes.
HAD SOME REMOVER IN VAN, NOT USED IT AND BEEN THERE 2 YEARS!.
I JUST SCRAPE AT IT WITH A WINDOW GLAZIERS KNIFE WORKS FAST AND GREAT WITH CARE..
SAME AS THIS BUT WITH STRAIGHT BLADE, MAKE GOOD CHISEL FOR WOOD AND BRICK TOO AS THEY CAN TAKE HAMMER BLOW..
th
Redsaw where did you scraper from ? Is it a decent one ,the last one I had disintegrated
Reply to Silicon remover in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Please can someone tell me the best way of removing a siliconed folding support rail that has been siliconed to a tiled bathroom wall at my mums...
Hi I had to remove the glass panels from this quadrant shower cubicle and I'm struggling to get one of the screens back in place properly. The...
hi all, hope you are all well, i was just about to start siliconing my shower tray (long running project) and found the exp date on the tube FEB...
Size of bathroom 230cm x 210cm Height 230cm Birmingham Area Initial problem Burst pipe underground in bathroom, concrete. Have had this dug up...
My bathroom Basin was installed some years ago by a professional plumber. For whatever reason, the waste was fitted using silicone rather than...
