Discuss Saunier Duval Enviroplus F24E repressurise issue in the Plumbing Jobs | The Job-board area at PlumbersForums.net
T
therickster
I have a SD wall mounted boiler which has a manually controlled refill loop for the heating circuit. It's worked fine until now - the pressure indicator shows 0.5 bar which triggers a fault code and it doesn't seem to want to re-pressurise (done before without problems) even when the refill loop is opened as per the instructions on the door to the controls. The hot water supply is fine and not affected so filters presumably ok. I removed the refill loop to check if the loop valves were ok and both seemed to work when physically pressed (ie they must be spring loaded). Does this loop need to be pressurised for the valves to work; there's a one way valve in that loop that appears to have a tundish but I can see no evidence of leakage here.
The three way valve is also weeping. We're in an area (Exeter) that is not designated hard water (?) but we do get some slight scaling. The plumber we used to service the boiler in the past seems to have gone offline.
Any experience with these boilers or advice would be very welcome
best advice, get in a technician to look at the problem. easily resolved
Reply to Saunier Duval Enviroplus F24E repressurise issue in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi I have a 4 zone / 7 loop UFH system. 2 zones (4 loops) always get hot when the system is on when the zone thermostats and actuators are off. The video posted shows when I turn on another zones the flow meters drop. (Kitchen prep and kitchen TV are the issue, two at either end of the...
Hi folks - new here and looking for a bit of advice. I've got a British Gas 532/i boiler which is struggling for pressure - around 0.5 bar. Heating works fine through most of the house just struggles to get to the very top rooms. I don't think any bleeding is necessary, and I cannot find a...
Got up on Wednesday morning no hot water, (only cold water coming out of hot tap). Checked boiler, it had zero pressure and F1 fault showing. So I refilled the pressure using the filling loop, up to about 1bar which is where it usually is, which worked fine, had hot water all day. Same thing...
Hi All, Hope somebody can help :) I have a vented HW system with a pressurised Ch system but got bit of a annoying issue, when the hot water comes on all seems ok then after about 15/20 mins i started to hear a trickling noise from hw cylinder which i can also hear in the boiler. The central...
 Our heating stopped working today. We've got a Veissmann boiler that's under a year old, and an older Megaflow cylinder, and two diverter valves (all about 10 years old). We also use a Hive thermostat.
 When I boost the hot water with Hive, the receiver near the boiler shows it's...
