Discuss Salus Thermostat wiring? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
dont know if this is in the right section but here goes
I need to wire a salus 300rf thermostat to a baxi duo-tec
If you have boiler installation instructions it will tell you all you need to know, get it wrong and you will blow the PCB, That's all we are permitted to tell you un less your a GS engineer
I would not wire a salus stat into any heating system I have fitted/worked on. You will be back in 6/12 months fitting something else as it will either break or the customer cannot work it properly. Try to persuade the customer to have a better branded stat.
Sounds like you have had some problems with Salus controls ! have fitted loads never had any problems with any of them, luck of the draw maybe !
I am a fully qualified plumber and gas fitter
But my gas safe has run out
I had a accident some years ago lifting a fire soround
Collapsed my disks pressing on scieatic nerve
The thermostat is for family
I'm ok with wiring but
Always had electrician to wire them up
Never fitted any mate. But replaced a shed load. You could be right. Might just be luck of the draw.:(:(
No offence, but If your gas safe has run out then you should know best you aren't allowed to touch the boiler unless you are gas safe.
Have you got the wiring diagram for the stat and boiler?
Here is a pic of boiler pic
thermostat and back of thermostat
You said the thermostat is for family,an then said it's for you? As above your not GSR anymore,we can't advise/condone you to fit it yourself.Its easy enough to do from your pic's do you not know anyone else In the trade that's GSR that could do it for you?
Not anymore
When I had the accident didn't get to see any work mates
My mum lives in a property owned by me
It's ok no worries
Mains Live, nuetral, earth into sender unit. Join earth with a connector. Run 5 core in sequence back to boiler .Grey and black into com and No. I cant see why you need to be gsr, a site would insist a sparky plays with electrics?
Need to remove the case to the boiler which can only be done if your gas safe registered
Nuff said, gsr to remove the case, sparky to install electrics and issue paperwork for landlord if it needs a new spur. No wonder have a go heroes prevail!
No need for a sparky
Just a good heating engy aslong as there's a fused spur
I have got a sparky to sort
Nice one, you need pianists fingers to get 5 core and 3 core all into the back of the salus sender unit! I personally have found them ok. Have had to change the frequency a few times where neighbours have them set the same.
Reply to Salus Thermostat wiring? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all I need to run this CH pipework to a radiator located beyond the electric wiring in the image below. Just to be safe I was wondering if there are any rules / distances, etc I need to be following when avoiding the wiring? Many thanks. P
B
  • Locked
Hi All, I am a 16 year old school leaver (Sept 23) looking for a local company to take me on as an apprentice plumber. I live in Benfleet and am looking to join a plumbing and heating engineer 4 days a week whilst I attend College to gain my level 3 plumbing and heating qualifications. if...
Billy Barnard
B
Fitted unvented hotwater cylinder building control looking forms signed it off job was in england i am qualified northern ireland send out a form to fill in what do u need to sign off in england as building control said they dont give out forms like they do in northern ireland
The left rear floor corner is highest (the shower pan touches/sits on the floor), sloping down diagonally to the front right corner (lowest). The front right corner shim is 5/8", the left front corner is 3/8" shimmed, with shorter shims under left middle and right rear corner. The pan perimeters...
