- Messages
- 14
Thanks for the advice. I am too nice, so they are taking advantage but rest assured, I told the plumber today that I owe the main contractor £3000. If it isn't fixed, i'm using that money to get it redone and they can hash it out amoungst themselves.That is NOT a suitable waste for that situation. End of.
Who did you pay to set it working?
Regardless, might I suggest you write to them to give them 14 days to resolve the problem to your permanent satisfaction. Take advice but in that letter you can say if it not resolved to your perm satisfaction then you will call in other trades people to remove what has been installed and redo it so it is done properly. At that point you will be taking them to court to recover both costs and an additional sum for inconvenience.
Basically, stop bu66ering about with them. In my opinion, the 'fault' is with the plumber not the tiler. The plumber should have supplied an appropriate waste designed for this situation. If they had done so then the tiles would have less of an issue.
In my opinion, the tiles need to be removed around the waste inside the tub too.
