Discuss Replaced ceramic disc but tap still leaking in the Plumbing Jobs | The Job-board area at PlumbersForums.net
T
TapsDMC
Hello All
It's 03:30 in the morning I have just joined and this is my first post. I have just given up in replacing a ceramic disc cartridge which I thought was going to be pretty straightforward but has turned in to a complete nightmare.
I have a KWC Domo single lever swivel spout kitchen tap. The tap has been leaking for a few months now from where the spout meets the body of the tap. I checked online every one was suggesting changed the disc. So ordered mine from KWC cost me a whopping £55 quid but thought it was worth it since doing job myself and new tap wil cost me 200 upwards.
So cutting it short i have changed for a new cartridge but its still leaking from the same place.
If anybody can help I would appreciate its driving me crazy.
Although I must admit it has been quite therapeutic writing here.
Have a look to see if it has got o ring seals anywhere and check them maybe worn
turn water of and enjoy your sleep :) you did not expect respond back at 3:30am did you !????
Hi
Thanks I did turn off and go to sleep, no O-rings just the cartridge. I have tried tightening the holding nut for the cartridge, also kept it loose with water turned on but it made no difference. I think the hex nut is what presses the cartridge down as you tighten to create a seal but I have tightened as much as I can but to no avail.
did you clean it before putting new cartridge , did you apply some silicone grease ?
Hi
Yes I applied some grease to the bottom of the cartridge and cleaned out the inside of tap to debris. Did not some marks made by previous cartridge but cleaned as much as I could.
On those kind of taps you need to remove the tap I think to gain access to the swivel O rings, don't think its the cartridge that's faulty.
when I did change over the cartridge I did think there wasn't much difference between old and new. The only problem I have with removing tap is that when it was installed it was fixed to the sink first then the sink was fitted in to the work top so it's impossible to reach.
I guess it's time to call in a professional!
It wiil be the o rings,have a look and see if there is a screw in the back or front of the body,this holds the spout in place
Reply to Replaced ceramic disc but tap still leaking in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have attached an image of the brass body within a tap. Having replaced a cartridge which has cured a leaking tap, I can see that there is a...
i can't tell if my shower tap (cock stop) is leaking or not ...............so after showering, the shower head will drip fast for 2 hours, then...
Hello. My mixer shower (non-electric) recently started running luke warm. I know this can happen at this time of year over winter but I've been in...
I have a dripping bath tap. Seperate to the spout. Quarter turn level tap from the wall. I need to change the cartridge as it’s dripping lots...
This is driving me bonkers! I have a Jaquar shower mixer unit - which has started to leak from the diverter cartridge. I think it's an early...
