Discuss How to remove shower diveter valve in the DIY Plumbing Forum area at PlumbersForums.net
This is driving me bonkers!
I have a Jaquar shower mixer unit - which has started to leak from the diverter cartridge. I think it's an early Florentine model circa 2006 though not 100% sure.
I've removed the faceplate, unscrewed the chrome collar - and now want to extract the diverter cartridge - but I simply cannot see how it comes out. There's a threaded collar with two flattened sides but for the life of me, this doesn't seem to unscrew - can't tell if it's siezed or whether it's actually all part of the main mixer unit.
Any pointers would be really helpful
It looks to me as if the flats and the threaded collar are all part of the body.
My guess is that the nylon adjustable 'stop' can be levered out and there will be a nut behind.
But that is a guess 🤔
Good call... I'll try that. I did think that perhaps the flats and thread were part of the main body - but why add flat sides if it could never be removed? It's just tempting someone to take a large spanner to it!
I'll try and lever out the nylon rim and see whether is shows anything.
Thanks for the help!
I wouldn’t try levering it out, will probably break something.
The flats are a pretty good indication that something will unscrew- get a pair of 24” stilsons on it and it’ll move no problem.
Thinking about it, there wouldn't be room to put a diverter cartridge through the hole in the centre with the nylon part. I'm sure Ben-gee must be right!
Stupid suggestion of mine 🫢!
The threaded part with flats must be removable, it would be impossible to cut the thread so close to the valve body.
You normally see a small gap with material cut away so the thread can be cut off clean.
It's most likely a retainer ring for a plastic valve / cartridge body and would have a smaller thread into the valve body.
Run hot water through the mixer first to warm it up, might just ease the pressure off the thread.
I've cut out a panel around the whole unit now, partly so I can get a better angle on the flat sides for a stilson but also because I've just cannot source the correct cartridge and might need to replace the whole unit.
I'll update with news later on. Thanks for all the suggestions
Thought I should update for anyone else who may be looking for this kind of shower mixer replacement.
I completely removed the old unit - and still couldn't get the diverter valve out - it is completely siezed up. I replaced the unit with a Cruze Twin Round Concealed Shower Valve with Diverter - Chrome (CRSVC01D) and used HEP20 fittings with 15mm copper pipe to complete the install. The Hand shower unit (also Cruze) was the only part which used a flexible connector.
Job almost done - just need to reinstate the panel and tile it up.
Thanks for all the suggestions - sometimes it's better to cut your losses and start afresh.
Final update - shower panel refitted and managed to match the tiles at least. This is an 18 year old shower after all.
At least it no longer leaks!
Reply to How to remove shower diveter valve in the DIY Plumbing Forum area at PlumbersForums.net
