Discuss Recommendations for a sealant for misaligned bath overflow in the DIY Plumbing Forum area at PlumbersForums.net
hi all,
I'm just sorting the drainage for my freestanding bath. Due to a slight misalignment of the drainage / manufacturing error I'm unable to get the rubber seal for the overflow totally compressed up against the bath.
Any recommendations on an alternative to the rubber gasket like Plumbers mait, etc?
Cheers
Thanks, I would imagine if I use silicone or stixall I can just apply a bead around the rubber washer or would you abandon it completely?
Fernox LS-X sealant.
I fitted 2 Essex flanges to my hot water tank and whatever I did, one of them occasionally leaked.
I stripped it and applied some of this sealant to the cork washers, no more leak.
I also used it on a sink drain that wouldn't seal due to a dodgy rubber washer, again, did the job.
Specifically made for these types of leaks, can be applied to wet surfaces.
Reply to Recommendations for a sealant for misaligned bath overflow in the DIY Plumbing Forum area at PlumbersForums.net
Hi all I purchased a freestanding bath and when I came to cut the holes for the taps I realised the hole for the overflow is misaligned with the...
I am replumbing my lakeside hunting cabin (totally off grid, water from a well or the lake, solar power through a battery bank and now a large...
2K
Hi, a new member here, so first of all, hello to the forum! Posting because - I've got a couple of problems in a relatively new bathroom...
2K
  • Locked
Hello, I have had to replace my Vaillant 824/2E boiler as it was written off due to a leaking combustion...
5K
Dotty
N
  • Locked
Hey there, had some unfortunate problems with a local plumber. We needed a new oil tank fitting, and as my partners father is a builder, he...
5K
