Discuss Radiator blanking plug size in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, ive bought a flat panel aluminium rad off ebay and one of the 4 outlets is slightly larger than the other 3 by about 1 mm. Has anyone come accross this before and so what is the solution.
Cheers
Does it actually screw in? If it does I’d wrap some ptfe on the thread. If it doesn’t fit I’d be looking at contacting the seller. Whats the diameter of the thread out of curiosity?
Rake of ptfe and paste.
Or get shot.
Maybe why it was on flea bay in the first place.
That’s why I asked what diameter the thread was in case it was some Chinese knockoff with an unusual thread size. Jason, Ask for an exchange, if that’s the same get a refund.
If it's a bsp thread then the next size up from 1/2" is 5/8". You won't find anything in a plumbers merchants but possibly a specialist nut and bolt merchants may have something to bung it with. Worth a try if you want to keep the radiator.
Tried 5/8 today and its too big. Bugger. Would it be possible to make the hole threads larger or would all the bits of steel get trapped inside the rad .
Cheers
Errr, that looks a hell of lot bigger than 1mm gap.
1/2 inch 12.5 mm 15.
Jason, you can give me all the dislikes you like pal ;) but nowhere can I see what you claim to have posted.
Goodnight
This is a clip from opening post.
the 4 outlets is slightly larger than the other 3 by about 1 mm. as anyone come accross
Clearly.
The difference between 1/2 and 5/8 is just over 3mm so 5/8 being to big so gap is approx 2 mm.
If you dont have any sesensible/usefull comments dont bother posting and disliking my posts . Very childish
Clearly.
Well if you are going to add words here and there and mis quote you really ought to look in the mirror! Time to pick your dummy up.
Reply if you wish but you`re talking to the hand now.
Reply to Radiator blanking plug size in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, Sorry if question already answered in previous posts, but I can't find a solution to the below: We recently moved house to a new home that...
Our house was built in 2007 and we are the second family to live here - moving in in 2017. The central heating has been working fine - although...
1K
i have done a few tests on 5mm pvc wet wall before trying to fit a 1600 bathroom radiator, it's to be fitted on plaster board, there is a panel...
2K
Hi all, Got a nightmare situation with a central heating system I recently adopted. It's an open vent system with a combined F&E pipe, with a...
2K
Hi everyone, I'm new here! I've bought my first house - needs a fair bit of work doing to it, including the plumbing. I'm keen to do stuff...
