stakhanov
First, I'm new here so this question may be in the wrong forum if so please feel free to move it to where it is most appropriate.
I have recently had a new bathroom fitted and amongst everything else I've had 2 towel rads fitted. They are plumbed in but also have summer elements fitted.
When they were first fitted the plumber's "electrician" had wired them up incorrectly so that when I switched on the power to the summer elements it caused the whole house heating system to come on. But the rads did warm up and in general use the rads came on (perhaps a little slugglishly) with the main central heating.
The plumber and has "electrician" came back last week to rewire the elements and to regrout the shower for the third time, which was leaking to such an extent that water was flowing through the light fitting in the kitchen below. Bear in mind that I've waited from late August till early December for this visit and have not been able to use the shower in the mean time.
Anyway the shower does not leak now, at least after one shower. And the summer elements work when switched on. ... you can hear the BUT coming...
BUT
Now neither of the towel rads come on with the main central heating. The plumber has basically said he doesn't want to know, as he merely fitted the rads that I supplied.
First, are there any basic checks I can do or tips to try to get the rads to work. It seems unlikely that any pipe work got changed in his recent visit.
Otherwise is there somewhere I can go to engage an independent expert to look at the work that has been done to asses whether it has been done to a proper standard. To be honest I have lost any confidence in the plumber that did the work. (found through Check-a-trade) I have not even begun to catalogue the other problems...
Any help or advice much appreciated
BUT
