Currently reading:
Power flushes / rads not heating up - HELP PLEASE!
Discuss Power flushes / rads not heating up - HELP PLEASE! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hiya
We recently moved into a 25 year old house and all the rads were working except for the kitchen one which was stone cold as was the pipework leading to it.
We got a plumber in who fixed it but then our bathroom upstairs and small bedroom rads didn’t heat up. The plumber returned put some cleaning stuff through the system. After a few hours the rads upstairs were getting hot (all the ones downstairs were turned off at this point) and when we turned them back on, the rads appeared to be working.
We then had the heating off for a day or so and now it’s back on our living room and downstairs hallway rads, although get slightly warm, are not hot like they were before.
We’ve been told we may need a power flush but they seem expensive so we really don’t know what to do.
We dont mind paying it if the power flush will definitely work but I’ve read stories on the internet saying they are around £4-500 and a waste of money as they are not very successful?
Help! Does anyone have any advice or experience of this please?
It’s been non stop paying out with issues in our house since we moved here so it’s getting a little frustrating now.
Many thanks in advance.
Mandy from Hertfordshire
Find another plumber, make sure he tests the pump and all the TRV's before deciding to go ahead with a powerflush. A heavy duty cleaner (if that is the issue) should be able to get your system going without the need for a powerflush in my opinion.
i would change the pump as its lasted well, i would say its the same pump as when they put the system in
Small bore pipework will block very much easier than 15mm pipe. Clearing it is so difficult. A heavy dose of cleanser is required and also a Magenetic Filter to collect the deposits as they are loosened. Clearly a flush is needed. That damned microbore again!!
Can you get to the small tank in the loft and photo the water that's inside it? Dirty water inside the tank can help diagnose problems.
Also with the heating on, run your hand over the radiators, They should be warm / hot all over. Any cold spots will indicate a build up of sludge within the system.
That’s a good idea, I’ll go up and take a look when I have some good light...thanks for the idea
Reply to Power flushes / rads not heating up - HELP PLEASE! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
