Discuss Potterton promax SL making a humming sound. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
flesi
Hi guys, having a problem with a potterton promax SL making a humming /vibrating noises. Gas ratio & inlet pressure it's fine. Has anyone come across this issue before. Cheers in advance.
either swarf in the fan plastic venturi or a heat exchanger casting fault or sludge in the main heat exchanger or faulty burner
take your pick
Cheers gasman, I do suspect the fan, the boiler is only 2year old and the quality of water is fine.
If the noise happens on start up check the flue turret to boiler gasket - it could be perished
The noise happens after the boiler runs for a little while and it doesn't do all the time.
TBH even though i fit baxi/potterton combis i wont touch the heat only solo/promax/gold etc fitted one never again
I've had this problem on start up on fitting 2 previous vokera mynutes VHE's, you think its mostly down to sludge in Heat Exchanger? it does sound like the fan mind you, I know they are crap boilers but we don't get paid to powerflush or anything before fitting them.
Reply to Potterton promax SL making a humming sound. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
R
Hi, I have the combi boiler Potterton/Baxi Promax Ultra 40. When I set the temperature to (e.g.) 45°C, the boiler fire up and stay at max power...
2K
Renato
R
T
A constant ‘hum’ noise has started and I’ve traced it back to the water meter in the street in front of the house. The noise internally can be...
2K
Hi All, Hope somebody can help :) I have a vented HW system with a pressurised Ch system but got bit of a annoying issue, when the hot water...
Hi there, My boiler (Worcester Greenstar Ri) has started making a soft knocking noise when it turns on, and again a few times when it turns off...
Hi everyone, I'm hoping to get some advice on an issue I'm having with my Vaillant Ecotec Pro 24 boiler (R1 PCB). It was installed in 2013 and has...
