Discuss Plumber / Gas Central Heating Engineer Needed - Stourbridge, West Mids in the Plumbing Jobs | The Job-board area at PlumbersForums.net
djames77
Hi
I have a Baxi Combi boiler, no heat or hot water. Someone looked at it and said I need a new PCB but this might not fix the problem adding if the new one blew up I would need another PCB and also a new fan.
I'm looking for a second opinion, anyone available today to come and diagnose the fault and carry out the required work?
Thank you for placeing your works requirement on the forums,any member who can help please contact op direct
Reply to Plumber / Gas Central Heating Engineer Needed - Stourbridge, West Mids in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello, I am looking for a heating engineer to diagnose and resolve an issue with my Vaillant EcoTec 832 combi boiler. Job Location: Copeland Rd, London. Job Description: Problem: The boiler is not providing heating under normal conditions, although hot water supply is fine. Interestingly...
I have been facing central heating low pressure on unvented hot water RM Cylinders but can't see any leak on the PRV, expansion vessels and plasterboard celling. I have got unvented pressurized RM Cylinders hot water system with 27KW Worchester gas boiler with expansion vessels . When...
losing pressure
L
C
Looking for someone to join a motivated dynamic team of 7 engineers. Based in South West and Central London. Conpany has been running for four years. 8-5 £200 a day after CIS Deductions Overtime paid at £35 an hour Payday every Friday Van tools uniform provided
Clemmie
C
  • Sticky
I thought I'd create a master thread to move all of these similar threads into, over time like. If your central heating doesn't work boiler doesn't work radiators not working radiators or heating system is cold thermostat wont work or respond Then post a reply in this thread. Rather than us...
1K
My Grant combi oil boiler is giving me quite a headache at the moment. When I returned home last Friday I'd no heating or hot water. An engineer called the next day and diagnosed a faulty pressure switch. This was changed and everything seemed ok. However then the boiler began to lose pressure...
