Discuss Pipe Stat in the Plumbing Jobs | The Job-board area at PlumbersForums.net
brian b
Could anyone please tell me the correct pipe stat to buy to fit to my hot water return (central heating) pipe to control the circulating pump switching it on as the temp. rises above 45 degrees and switching it off as the temp drops below 45 degrees. I have bought a danfoss type AT 041e0000 temp. range 30-90 but this just turns the pump off at whatever setting on the stat i set it to when that temp is reached.
Thanks very much i appreaciate any help.
Regards,
Brian
Are there not 3 connections on the stat , a common, break on rise and a break on fall ?
I think if you go common and break on fall then set it at 45 it should work.
Check the wiring diagram that came with it
Thanks very much Toddy I will try that,
Brian
Thanks Toddyplumb Stat sorted, I had it working the opposite way round like on a hot water cylinder switching off when temp was reached. More haste less speed.
Cheers for the advice.
Brian
Reply to Pipe Stat in the Plumbing Jobs | The Job-board area at PlumbersForums.net
So a strange conundrum regarding water temp if anyone can help resolve, would be much appreciated. Ive tried to give as much info as possible to...
Have a sytem boiler with unvented cylinder with 2 heating zones plus hot water in a house we moved into recently. To start with we were always...
M
Hello, We’ve recently moved into a fairly old, fairly big detached house (i.e. fairly draughty, but not too bad by any means) with a fairly new...
MartinPod81
M
Hello friends - I really struggle to understand my heating and hot water system I posted my question on Diynot but it ended up being five pages...
I have a conventional system, Potterton Prima Boiler, into a Pump into a Motorised Valve that feeds the Radiators and/or the pipes in the Hot...
