Discuss Pan Removal of a Concealed Cistern Toilet? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
R
RRFAN
Looks like the soil pipe seal has gone on this and is leaking on the bathroom floor. Problem is the whole cistern is tiled in and there's no way to access the pan from the back.
There's two large bolts that are protruding from the wall and the pan sits on these. I'm very tempted to remove the pan off these, but I'm worried that the connection where the pan meets the cistern (in the wall) is connected by something other than a push connection and therefore will snap.
Has anyone ever removed the pan this way or do i have to knock down the wall and tiles to get to the back and unscrew something.
Thanks for all help. the site looks like I might be here often! :)
Im my experaince of the wall hung ones ,the flush feed and waste are simply push connections..
If you loosen the bolts off and slide the pan forward then you will see the connections ..
Hi You may find its the flush pipe connection that causing the problem?
If the pan is on bolts,there should be a proper concealed wc frame behind the tiles,this should also hod the soil pipe and flush pipe in place when you remove pan,cut any silicon seal that is around pan sealing to tiles,undo bolts and just pull free,tipping towards yourself slightly to stop trap water spilling all over,if tiled floor get some cardboard or old towel to sit pan on when out
check soil pipe as not twisted downwards at back as often happens due to lack of support at rear
thanks a lot guys, great info. will give it a bash tonight and see what i can find!
When reassembling use a bit of silicon grease especially on the flush pipe cone socket in the pan, not the cone itself or it may slide like mad.
Reply to Pan Removal of a Concealed Cistern Toilet? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, fitting a back to wall toilet in a small cloakroom. The soil pipe is a vertical clay pipe about 20cm from the wall and so I will have to build...
2K
Deleted member 120897
60's ranch, with single bathroom. Tile over concrete slab. Toilet is about a foot from exterior brick wall. Vent pipe is in interior wall behind...
As part of a slow DIY bathroom refit I've removed the old toilet from the original location next to the soil pipe (and obviously capped off the...
Hi all Relatively inexperienced homeowner here. Apologies in advance if I get any terminology wrong. Today I noticed some limescale accumulation...
1K
Hello all, We have a small bathroom, which currently has the toilet on the outside wall, and the sink on the inside wall. What are the...
2K
