Discuss P,d,m brass fittings is it for imperial or metric pipe? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Inverness
I went after college to do a homer but I had limited material as I didn't know what to expect. I Went to change the bath taps for a bath mixer but before I cut any pipe I noticed the brass fittings are stamped p,d,m can someone tell me if the copper pipe will be metric or imperial. So I know if I need green rings for next time I go round I'll be prepared.
Any old skool plumbers out there I just want to say I respect the patience and skill that was involved compared to nowadays.
as this bath pipe work must of been done first then the bath.
I can't really answer your question as I can't say I've seen it.
What you want to do is buy a few Stanley organisers and get a few fittings of each in compression and end feed and male irons female irons type thing. Then olives, fibre washers etc then you don't have to worry.
Then continue for a few years and you will have almost a mobile merchant like most of us on here
Good idea I'll do that. I didn't know you can get imperial and metric yorkie couplin. Amazing the stuff you can buy nowadays.
you cant only end feed
Just for you lol
I got about six boxes left from a job lot I bought
would you be willing to sell some (ie one or two boxes)?
You can get solder ring (identical to Yorkshire) 3/4" x 22mm connectors in other brands
link as have asked locally for a few years and they say the only ones they know of are yorkshire (which dont make them any more) or endfeed
(decent ones)
(decent ones)
Williams do them in endfeed and solder ring
only the 22-3/4 in SR though
Yeah as above get some organisers, don't buy cheap wait till the good ones are on offer and get a few then solder/compression/iron/odds that you wont know you need till you need them
/one for toilet and tap spares and repairs/and such
If you're talking about brass soldered fittings on existing pipe, then I would think it will be original 3/4
Do you have to change pipe work to change taps, maybe enough play in pipes to accommodate new taps
The thread length should be similar
Sorry what I meant was comp fittings with imperial olives
You can also get imp/met couplers in soldered and they are handy to have a few of.
I wouldn't bet on the threads being same length if it is old 3/4" copper with brass soldered connectors. It would be very old and most likely the threads will be longer, therefore leaving the old pipes short of the new taps.
Two flecks and two convertor rings with luck you won't need to cut any pipe as they could be a straight swoop if you want to keep it solid pipework take 4 3/4 tap extenders
The pipe work is really tight space. I was going to use pushfit flexi with jg imperial conversion couplin.
I have never had to use push fit or flexies.
If the pipes are too short you can cut the front one out and do the back pipe first.
Actually easier anyhow to do that, even if pipes are correct length.
A couple of brass connectors and job done
Reply to P,d,m brass fittings is it for imperial or metric pipe? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
