Discuss Old radiator and no key, how do i bleed or just replace? in the Central Heating Forum area at PlumbersForums.net
I have a very old radiator for which we cannot find a key for. It desperately needs bleeding, any ideas on how I can do it or is it time for a new radiator?
Try a Brass one like this, the end is a smaller diameter;
The typical soft alloy ones are too big;
Some brass have larger ends and would be too big as well;
Looks like a removable complete air vent anyhow, (I copied and magnified image) so should be possible to just replace the lot if it screws out with a socket of correct size.
Alladin Easy bleed, where you drill a new hole and it cuts it`s own thread? Hasten to add that I`ve never used one myself.
Reply to Old radiator and no key, how do i bleed or just replace? in the Central Heating Forum area at PlumbersForums.net
Oil boiler (now~15 years old) unvented system with 17 radiators. We moved in 5 years ago and I had to keep bleeding the same radiator. The bleed...
Hi everyone, I am looking to bleed the radiators in my rented flat as winter is now starting to kick in and want things to work as efficiently as...
Hi, I seem to have lost a bleed nipple from one of my rads somehow. It’s a double rad, one side of the rad has a nipple, the other is gone and I...
Hi, Sorry if question already answered in previous posts, but I can't find a solution to the below: We recently moved house to a new home that...
have a mixture of radiators range between 25 & 60 years old.Im having a new boiler fitted, do I change all the rads or just the old ones? Cheers
