Discuss Oil pressure reducing valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Inverness
hi guys, I'm planning to locate a new oil tank but the problem is the height will most likely to be greater than 4 meters from oil pump. I know you can use a oil pressure reducing valve have anyone used this before?.
Used on in a cellar a few years ago.
Can’t remember the make. But had no problems.
What can happen if you don't install a prv on a oil line if it's above 4 meters from burner.
Reply to Oil pressure reducing valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
