R
redmohican
I had a similar job to go and sort out (leaking under bath). The bath panel was tiled and I had to smash it off. It was hiding some very shoddy workmanship plus an assortment of pizza boxes, *** packets, fish and chip wrappers and general rubbish which had been swept under the bath.
Another thing you need to check is has the bath been set into the wall if it is a solid wall, and plasteted back in or has it simply been pushed up against the wall and fixed?
Does any of the wall where the shower is have plasterboard behind the tiles as if it does, if it gets wet it will disintegrate?
Make sure you have enough spare tiles so that the bath panel can be redone properly.
Thankyou for the reply.
As far as I know (and saw before the panel was put on, the only thing under the bath was a lot of polystyrene packaging, that the contractor put there to further deaden the noise of the pump.
As for the shower wall, this was a wooden wall (wood bought by contractor), that was tiled over, it wasn't plastered, or plaster board used.
I do have enough tiles for the panel to be done properly (luckily).
