Discuss Moisture comming up through floor tiles in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
Johnrwoods
Hello all
i have some sort of liquid coming up through the floor tiles in my mums kitchen. It appears in about half a dozen places where the grout is.
its not just water, it's slightly sticky and smells a bit like silicon. There are no signs of any leaks above or around though.
The house is pre war built. The tiles were laid around 9 years ago, and it's a wooden floor. I know i 'll probably have to take some up to investigate, but just wondered if anyone had any thoughts on what the cause might be.
Many thanks
Welcome to the forum John, any chance mum is using a new floor cleaner?
Hi and thanks. No she's in hospital, I noticed the moisture, cleaned it up, and it re-appeared by next day.
In that case I`m out of ideas, sure someone will be along with a better idea though.
Welcome to the forum,
First thing I'd do is checking the ceiling all surrounding areas. Check toilets and basins above of any sign of leakage.
Obviously you will need to take some tiles off to investigate under the wooden boards. Try to check your kitchen tap as well the pipes too there might be a leak though.
Without breaking those tiles you could use a multi tool to remove the grout firmly.
Reply to Moisture comming up through floor tiles in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello there, Relatively recently we had a new en-suite fitted (complete rip out of the old fittings, and old wall tiles and floor carpet). This consisted of a quadrant shower enclosure, a stone-resin shower tray, new ceramic tiles on the floor and half tiling on the walls. All the work...
I have a potential issue with a toilet on a newly tiled floor and looking for some advice on acceptable tolerances and what to do. The back of the toilet sits at about 2mm from floor and the sides vary between 2mm - 16mm. It is a closed back on toilet base and approximately 190mm to 200mm from...
1K
Hello, Our bathroom was installed 9 months ago by what we know were tradespeople who did not have the skill or experience to do so. Several revisits to fix leaks, poor siliconing and retile whole wall and reinstall shower tray were needed and in the end we just accepted it, even though it’s...
2K
Hi, Looking to see if anyone can give some advice please. My Baxi boiler has been losing pressure and I am having to top it up approx. every 4 hours from 0-1.5 bar each time. This has been going on a week now. I have also started to notice small drips running down my condensate pipe...
My bathroom Basin was installed some years ago by a professional plumber. For whatever reason, the waste was fitted using silicone rather than plumber’s mate. The floor was originally tiled, but I replaced it with high quality vinyl, when fractures began to appear in the grout. As part of this...
