Discuss Mixing metals on compression fittings in the Plumbing Jobs | The Job-board area at PlumbersForums.net
The pipe has the blue plastic lining, but the inserts are solid white. See picture. Should I use different ones for copper compression fittings?
Reply to Mixing metals on compression fittings in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello, I'm considering fitting an isolator valve to 15mm feed to my toliet cistern. It would require cutting off an existing compression fitting...
Hi, I am probably being unduly paranoid here but I noticed under our kitchen sink that there is some corrosion evident on a small section of...
Hello, I have a troublesome fixed 15mm copper pipe with isolation valve going to my toilet fill valve. It's too tight for a Flexi hose. Can I use...
Hi, hope all is well! I’ve fitted a compression cap on two of my shower mixer copper pipes (15mm). One of them has scratches and burring and is...
I have Honeywell Valencia TRVs 10mm pipe size, I’m making mods to accommodate larger rads and it looks like the 10mm compression insert is special...
