Discuss Mixing metals on compression fittings in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Annoyingly I have used a copper nut on a steel isolation valve and the corresponding steel nut on a compression copper fitting (15mm). Should I dismantle and redo? I will have to buy a length of plastic pipe and new olives as well as drain system. Or will it be OK?
The fitting was from screwfix described as brass, steel and plastic.
https://www.NoLinkingToThis/c/heati...p=managedredirect-_-plumbing-_-isolatingvalve
I attach two photos. Thanks for help so far
The ones with the extra blue o ring eg the super seal ones ?
Reply to Mixing metals on compression fittings in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
I am in process of replacing an existing sink with a new stainless steel one. The existing tap is plumbed directly to copper which means that it...
Hi, I have an old steel water mains pipe (approx 45mm) that I need to connect to a new pehd water mains (25mm). I can't get at it to create a new...
