David C
Can anyone help please? Recently I had an engineer to look at our boiler that felt the problem of the boiler overheating would be solved by adjusting the output levels e.g. reduce the burner etc. He adjusted the setting in the maintenance controls to reduce the output.
This didn't help as the main problem was the whole system needed flushing out. After flushing the system is working well apart from the output is only heating the water flowing through the boiler to 49 degrees c.
Can someone please tell me what setting I need to change to increase the output so that the boiler heats the water more?
Thank you,
regards
David C
Thank you,
regards
David C
