Discuss Left boiler tap open wrong way in the Central Heating Forum area at PlumbersForums.net
Hi
I recently posted a problem I was having with my boiler pressure filling tap not letting in water - didn’t get a reply as per - but I have found out why and that is I had turned the right knob the wrong way hence why the left tap which brings in water wasn’t working.
My question is as I have clearly left the right knob open for days thinking it was closed, will this have harmed my system in any way?
You may want to check the system pressure, and pressure relief valve (Prv). You may have caused the prv to operate, and this may not seat correctly. Also I’ve known issues be caused to the expansion vessel for his reason too.
Did you notice the boiler pressure rise / above 2.5 bar ?
Looks fine then I would say
Reply to Left boiler tap open wrong way in the Central Heating Forum area at PlumbersForums.net
Hi, Later this year I am going away for a 2 week holiday and as the weather will be warm there is no need for the heating to be on and arguably no need for me to needlessly heat hot water. My intention was to turn the boiler off along with the mains water when going away. Now, I have heard...
