Discuss Leadloc size pics attached in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Any ideas which leadloc size I should need? I'm thinking 3/4 9lb but any guidance which I need would be appreciated.
I would normally but 7 and 9 in both sizes eg 1/2 and 3/4 you can always take them back
Thanks guys, one of them situations if I cut the pipe and can't get the fitting the water has to stay turned off.
Hand tight then a full turn be enough? Don't want to crush the lead.
I was looking at the Philmac fittings but double the price.
Start in the morning!
A decent independent plumbers’ merchants will definitely have what you need in stock, so don’t worry on that score.
Assemble everything together with lead loc finger tight plus half turn (I have strong fingers) and at the end of all this (presumably in the house?) have the stopcock and a tap open- so that there is not much pressure when you turn water back on.
Then turn the water back on attend to the lead loc, nipping it up gradually if required until it’s watertight.
Then close the tap and stopcock in the house and recheck the lead loc, now that it is subjected to maximum pressure.
Morning again
The instructions are saying the olive taper this way. Tapers usually go into fittings so the other way don't they.
Or is this just totally different with it being lead
Regards
Reply to Leadloc size pics attached in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
Hi all, I'm installing a concrete patio out back. By the wall under the kitchen sink I have an existing P-Trap gully for the grey water from the...
Our kitchen mixer tap has started dripping. Like so much of the plumbing in our almost new build bungalow, it is lacking! The plumber didn't...
I have attached an image of the brass body within a tap. Having replaced a cartridge which has cured a leaking tap, I can see that there is a...
Show us your fanciest radiators you've installed! We would love to see them! I love this Milano vertical radiator in the kitchen space. What...
