Discuss lead w.c. waste in the Plumbing Jobs | The Job-board area at PlumbersForums.net
R
REDSAW
just priced up a job to replace a w.c l/l system and some other work.
the outlet is lead at ground level (on floor boards runs 10'' on floor).exiting with 90 elbow 2' into stack.
i forgot to measure the width of the pipe in w.c and think its 3 1/2''.
does this sound right, as i need to get the stuff before i go to fit as the location is miles from merchant and being tight i dont want to buy more than one fitting in stock.
secondly, i am thinking of using a jollyflex by pulling the lead pipe up slightly from the floor for collar clearance to save costs on renewing the soil pipe to stack.
anyone have opinion, details and a link for the jollies. and do they do 3/ or 3 1/2''
thanx.
I do have an opinion but it's not a sensible one!! Rather you than me with this job - best of British!!
not too sure about the one from toolstation , I bought one from local merchants a while ago specifically for a 3 and a half inch which you can cut some of the fins off to fit as you see fit worked a treat into old cast iron.
DFD67465-8F71-B9AF-A211-C6B205045DB6
1.02.28
there is a finned one on toolstation too John wether that is any good i don't know :D
thanks lads,
i am more intigued if there is a pdf on there fittings somewhere.
thanks lads,
I always use the Mac Alpine ones although they are a bit less flexible. For Lead usually 3 1/2 inch and cut away as much lead as I can, if tight just get a hammer and gently boss the lead out to the right size works every time.
Reply to lead w.c. waste in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Just started gound work on self build bungalow and wondering best way to do below ground soil pipes. For toilet I was going to go straight down...
The left rear floor corner is highest (the shower pan touches/sits on the floor), sloping down diagonally to the front right corner (lowest). The...
