Discuss Is this glue against regulations ? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
O
Old Account
hi guys,
I got called out to inspect some plumbing works.
Boiler: brand new vaillant, no filter, no reducer, no carbon monoxide alarm, prv pipe facing 2 sockets
Flue: no access to the flue at all, it looks pretty much they used an old existening flue
The prv pipe goes straight out into a little extension / bended down and right underneath is a 240v socket. It's not leading to outside.
System hasn't been flushed.
Company walked away without commissioning the boiler without registering the boiler.
What has to be done to make this to current regs and most of all safe ?
I am about to give the job to my gas safe mate. Just wondering what you think about this job and what would you roughly charge to register the boiler with gas safe? I think the flue, access and a filter should Ben installed, am I wrong ?
Would love to get an advise kind regards.
Ron
Looks like boiler will have to be refitted as flue looks too close to the roof and access to the flue is a must to meet regs. Filter is a must in my opinion but no regs insisting that you fit one.
The flue should be a vertical one. Not what is there but would like more pictures as if they have done that with the flue. Would like to see what the install is like.
Basically the boiler is hanging in the bathroom entrance left hand side,
Flue disappears with a bend inside the extension roof without access and the flue looks also not new looks like used from previous boiler.
All wrong get your gse to quote for a new boiler direct to customer
Ok, what shall I tell the customer why the boiler has to be re installed ? What reason can I give to do so ?
What plumbing works were you there for ?
If they have used the existing flue !
Am I following you correctly Matchless. ?
The flue (and I could be wrong here), looks like the old baxi flue?
if it is the one i'm thinking of has it not got an aluminium exhaust ?
It would be RIDDOR reportable?
He called me up for a leak ( which I assume is central heating under a boarded floor with new carpet), plumbing under the kitchen sink very untidy pipework takes too much space, boiler loosing pressure every 5/6 weeks
Installing a new radiator vertical one.
Wouldn't touch anything heating related till a new boiler has been fitted as its turn off and cap job
So you wernt there to have a look at the boiler?
I also went out for banging pipework which only occurs when basin ( quarter trun tap ) and toilet is been used,
So i wanted to ask you how to solve this ... do i need to change the quarter turn valves ? Or prv at the mains ? , shock arrestor ?
What would you do ?
Ok, does the flue look new to you ? To me looks the old existing one because the foam around it looks old too. Can you install a boiler in the toilet ?
Shall I tell him the boiler is RIddor and needs to be re installed to current regs ?
I wouldn't either. Get you Gas Safe mate to attend and do a report to check everything.
Depends what does the toilet fill valve look like if it looks ok
Fit a shock arrestor under sink as I bet pipes arnt clipped
Hahha you are quite right. Leaving the prv pipe inside the extension facing down to the sockets hahah
Is that definitely the flue outside ?
The one inside looks downhill (unless it's just the photo )
Get your gas safe engy to do a site visit and let him do it / go through it himself
They've got those fancy old Victorian toilet and taps but brand new with a push button flush valve but with handle
You say the flue is hidden. Is the boiler in the middle of the house or on an external wall?
Thanks very much to you all for carrying so much!
Much appreciate to every single one !
Thanks guys
Flue is the bathroom which has a bend inside the extension roof and then you only see the flue on the slope roof very close the roof ... there is no access to the flue pipe whatsoever
I couldn't see any other flue except from this one, even though it needs access to the flue regardless if the one is been vertical or horizontal...
Flue is the bathroom which has a bend inside the extension roof and then you only see the flue on the slope roof very close the roof . there is no access to the flue pipe whatsoever
This is how I would word it
You can either talk / send a letter to the owner
Saying you don't like how the boiler has been fitted but your not gas safe reg so you would recommend someone who is checking it out
You can find your own gas safe engy
Or I can recommend one
Mr jones
Ahfy gas engineers
395369427)35@£
Somthing like that etc
And let them go direct to your gas safe engy / get somone else
I can't believe anyone would use that old flue onto a new appliance.
There must be something you're missing ?
Are you sure they haven't just left it in the wall ?
Mr jones
Ahfy gas engineers
395369427)35@£
Thank you very much Shaun much appreciate will definitely send it to him
Honestly I couldn't find any other flue in the house. There is also no loft space
Cant just shut it off till u have your definative proof that its dangerous,
matchless = do all your saftey checks, emmisions , check the flue , then accertain if its at risk or it is dangerous
If it was me and it was dangerous then cap and warning and certainly not new boiler simply a new flue , no sense costing the poor customer a load of money for no reason,
Certainly looks like a cowboy who installed it,,,
Is the benchmark filled out and all tests done and signed ???
He's not GSR Kris. (matchless)
He cannot do checks he is not Gas Safe
No benchmark that's why he asked me about the commissioning but I cannot do it therefore I'll get my mate to do the job with me. Thanks for your responds and help
It's a pleasure to ask you all guys
Who built this house you're working in matchless ?
Jack ?
How's that fence panel down there under the house?
I know it's my screen not showing photo right so I can't make it out properly?
It looks like a large plywood extension built on a fence LOL
I haven't got a clue about the fence extension hahaha didn't see that :) ..
I am not working there just went out as the customer asked me to come and check the water hammer, pipework alteration under the sink, leak in the floor / central heating, installing new vertical rad
I believe if you install a boiler inside the bathroom you need to consider the zoo nes too don't you ?
Reply to Is this glue against regulations ? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Flue Snugs Hello all new member here. Flue snugs. I’m seeing a lot of boiler installs on you tube that don’t have flue snugs to comply with...
I just had a quote for a new boiler install as follows I dont undertand why a 15-60 boiler pump is needed and a 25-100 pump is needed as well I...
Hi guys, Just looking for a bit of advice really. last week we had our carbon monoxide alarm go off upstairs. We have 2 alarms in the house...
Had conventional boiler and tanks removed last year and new combi fitted and just recently had it serviced but the guy who did it has given me a...
Had our gas Baxi Combi inspected and serviced today, as it has been every year. Gas safety cert issued and says all okay, but engineer gave what I...
