Discuss Is it white abs or white pvc in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
How can you tell the difference between white pvc and ABS if the pipe has been cut in a way that doesn’t show the pipe details.
Reply to Is it white abs or white pvc in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi guys, These sleeves cover 10mm PVC central heating pipes (see picture and ignore tape measure) and I believe this is what makes it possible...
Hello. I'm new to this forum and I'm hoping to be able to learn some things as well as contribute as best I can. This might seem like an odd...
I have a garden setup with metal pipe at each end and a pvc run in the middle. Proposed. That's what i want to do. Join the two with water...
Hi all, Have got an old 60/70s PVC soil stack, the Toilet is going into a Hunter branded socket which has an old O-ring design (quite flat with 3...
